Blue_Escape
Thread starter- Joined
- May 22, 2005
- 4
I have a 1999 40hp 2 stroke Johnson motor, the model is J40TPLEEA. It was originally a tiller steer with electronic start that I have now <br />converted to remote control. All went well till I took it for it's first test run on the water...After a few minutes running the "NO OIL" <br />light and warning buzzer on the System Check Gauge came on. Now I thought this was strange as this motor uses pre-mix 2-stroke fuel, <br />there is no oil tank on it! The original (tiller)set up had a System Check Gauge connected but when I upgraded I installed a Tacho/System Check Gauge and a new wiring harness. Unfortunatelly I didn't notice if the old wiring harness was "modified" before discarding it...lesson <br />learnt too late! I am assuming that the "NO OIL" (and possibly "LOW OIL") circuit(s) needs to be isolated or looped somehow to eliminate the "false alarm"?!? Any help would be appreciated.
