!983 Wellcraft Ignition Switch
avbug
Need to replace my ignition switch and having trouble sourcing the right switch. Would it be matched to the boat or to the engine / outdrive assembly?
1983 Wellcraft 200 Elite with a 5.0 Mercruiser
Thanks! Bill
Bt Doctur
should be a standard 3 wire switch available almost anywhere
if you have off, run, and start, its a 3-wire switch like BD posted
if you have off accessory, run, and start, its a 4-wire switch.
beyond that, you have your choice of plastic or brass body
avbug
It does have an accessory position to the left but I don't think anything is connected to it.
Thanks for your input.
Bill
