982559 — CYLINDER & CLEVIS ASSEMBLY
NAVYJOE
1982 Searay bow rider with v-6 305 GM. 982559 — CYLINDER & CLEVIS. At the end of the cylinder has a large screw with a lock nut and washer. The screw has broken off from the cylinder. Any suggestions?
Bt Doctur
CYLINDER & CLEVIS.
need a bit more info than that , where is this clevis located?
need 3 posts to be able to post pics. and after that, on your 4th post you can upload pics and they need to be down-sized to about 400kb
Bt Doctur
0982083-0909941-0982080-0982559-omc-chevy-v6-v8-stringer-power-steering-actuator-assembly-983732-982.jpeg
Bt Doctur
If I read you right thr clevis broke off the cylinders threaded end? Then you need a new cylinder or a used one if available
