98 Johnson 130
dtide
This thing is a dog to start after it sits for a few months. Any ideas?
Johndhii
Re: 98 Johnson 130
Make sure your following the proper cold startup procedures. Did you put any type fuel stabilizer in it? Check the water seperator, you may need to replace it
SparkieBoat
Re: 98 Johnson 130
the 10% ethanol fuel begins to seperate after 3 weeks to 3 months..use a good marine fuel fuel stabilizer for ethanol fuel. or drain old fuel. also drain carbs before sitting up.
boobie
Re: 98 Johnson 130
The fuel stabilizer and the CORRECT start up procedures are probably your best bet. Ever read your owners manual ? Lots of good info in it. Another thing that has happened to those vro mtrs is when they sit oil will bleed into the carbs. If you pull the carb bowl drains and flush out with fresh fuel it will sometimes help.
dtide
Re: 98 Johnson 130
I have read the manual and I use star tron stabilizer and have NEVER put gas with ethonal in it. I crank and crank and crank, when its does hit it runs like a champ. it just takes forever to get it started.
dtide
Re: 98 Johnson 130
Thanks boobie that might be it. The oil leaking into the carbs. when it does start it smokes like cheech and chong.
boobie
Re: 98 Johnson 130
If it smokes that bad try the carb bowl flush trick first before trying to start it the next time after sitting for a long period of time.
dtide
Re: 98 Johnson 130
Thanks for all the comments. I replaced the bulb and fuel line even though they looked ok, Tightend every hose clamp I could find and guess what. This motor runs better than it ever has,cranked right up.
boobie
Re: 98 Johnson 130
Did you have to flush the bowls or not? Let us know what happens in the future after the mtr sits for a longer period of time.
dtide
Re: 98 Johnson 130
I think the problem was when it sat for a few months all the lines went dry and maybe was sucking some air til they had gas running through them.
boobie
Re: 98 Johnson 130
You may be on to something. If air some how got in the fuel lines the VRO will pump more oil causing your mtr to smoke on first start up. Anyway, glad it's working and keep us posted.
dtide
Re: 98 Johnson 130
another thing is I replaced all those zip ties on the fuel lines with SS hose clamps. I dont think the zip ties clamp down enough.
boobie
Re: 98 Johnson 130
If you get the correct zip ties they work good, but the old standard ones won't. Just keep us posted as to what happens down the road.
dtide
Re: 98 Johnson 130
Three trips and running like a champ !!!!!!!!!!
boobie
Re: 98 Johnson 130
Still, let us know how it starts after sitting a couple of months. Glad to hear it's okay now.
