98 Evinrude starter pinion.
Chuck4741444
I just bought this 98 evinrude 9.9 pull start, the gear that turns the flywheel is ground up (plastic) and doesn't drop down with out tapping it down, but it cut a grove in the flywheel.
Honorary Supreme Mariner
Your motor is NOT a 1998 model.-----Model # is ?----Or perhaps a typo and you meant 89??
jimmbo
That design of Rope Starter was first used around 1979
jimmbo
If I remember correctly, after 92, they went back to the Recoil above the Flywheel
kbait
Spring under starter gear should ride in the bottom slot of pinion.. try that first
