'97 Gulfstream Trim Tab Pump
One More Time
I just test drove a 1997 Gulfstream and couldn't get the trim tabs to operate, so the owner and I started looking for the location of the hydraulic trim pump but we weren't able to locate it. I followed the hydraulic lines which go from the passenger?s side across to the driver?s side line which then gets bundled with other wiring up the driver's side out of sight. Where is this pump generally located?
One More Time
Re: '97 Gulfstream Trim Tab Pump
After searching around I found it in the cabin on the starboard side under a small hatch tucked way in. The prior owner said that he replaced the blown fuse and that it was running, but it's not. Let the fun begin!!!
