I recently bought a boat with a ?97 175hp Ocean Runner on it. Sat for at least 6 months, maybe more. He (previous owner) wasn?t very astute about understanding how to care for an unused engine. So, I?ve been working on bringing it back to life. Spent 3 weeks doing cosmetic hull work, and just getting it back in the water. Low speed idle in gear has been an issue since day one.
Fuel has also been an issue. Both what was in the tank, and what I can get. Drained it down as far as I could. Replaced spark plugs, thermostats, and water pump. Decarbed with OMC engine tuner on the muffs just before putting it back in the water. Replaced the existing fuel filter with one of the Racor?s with the clear sight glass in the bottom. Water has definitely been an issue. I live in the Cayman Islands. Quality is not their forte?drain some sludge out of it pretty much every day?
Filled the tank with fresh fuel at the local pump. You don?t want to know how much I paid for it?
Ran about a ? tank on Saturday with no problem. Sat on Easter Sunday because it rained all day, and took it out Monday. Started having low RPM problems pretty much from the getgo. Runs like a raped aped from 3000~4500 rpm. Not opened it up to WOT yet, so don?t know what top end is. Want to get the lower range worked out first. It?s a fishing boat. And performance at trolling speed is paramount. Below 1200 rpm, it coughs and sputters, then dies. Starts right back up for the most part, with occasional over-revving. But have read that may be a de-carb process. Will defer that for a few more outings.
Sooo?
Just bought rebuild kits all for the carbs. Got the first one done. Been other post thinking these carb don?t have idle speed adjustment. A while back I pulled a carb off, and would have thought the same thing.
But tonight, while I pulled the first one off, I saw a screw I missed the last time I pulled one off. They?re not in the carburetor, they?re on the throttle plate. I missed that.
Shades of synching a pair of Holley Double Pumpers on a big block Fords in the 70?s comes to mind?
With those, the initial setting was 1 ? turns out from bottom, and play it by ear. I can do that?
Bottomed out that first carb by finger (have to go get the right size tool tomorrow) before I pulled it off, and it seemed to be about 1 ?.
Anybody got a suggestion for the initial back off on the needle valve? I saw a post somewhere that said 9 turns...???
That's just not anywhere close to consistent with the first one I pulled off the throttle plate.
Appreciate any help in advance...
Sooo?
