96 Rude 60deg. V4 looper--block removal
Frank Acampora
My manual is really not clear. In order to remove the block, must the two 3/4 inch head bolts holding the steering arm be removed? Also are there any "hidden" bolts? I removed the six 9/16 head bolts from the midleg and the 3/8 head bolt under the thermostats--also the two 3/8 head bolts near the front of the block on each side. Block won't pop loose prying at all four pry points, leading me to think something is still connected
Faztbullet
Re: 96 Rude 60deg. V4 looper--block removal
Yep, 3/4 bolts gotta go!!
