96 regal cuddy transom replacement
Matstang
Re: 96 regal cuddy transom replacement
Thanks! I by no means know what I'm doing, but I can read and copy what everyone else is doing! I've learned a lot from this boat and this forum. I originally had a volvo engine, still a ford 302 only carbureted. I really didn't know what raisers and manafolds were, and the importance of maintaining them. The guy who sold me the boat even told me they will need to be replaced in a year or so. Well, I didn't. And the heads were trashed as a result of it. So I found the OMC EFI engine I have now for 3K. Thinking back, I should have never went with a ford and switched over to a chevy 350. At the time I did explore putting a 350 in, but was afraid of the motor mounts and got scared of all the modifications I had to do. If this engine goes, I'll be going the 350 route. I'm pretty confident I can make it work now. The outdrive is a single prop volvo SX. I have had no issues with it. I'm pretty happy with it.
I'm still learning simple stuff. I thought it was normal to have water in the bilge. And the pump kicking on every hour was normal. Found out it wasn't...The saw the transom was rotted. Looking on craigslist I also noticed that everyone's engine's looked so much better then mine. I'm guessing this was because they didn't always have salt water hanging on in their bilge evaporating up into all the engine parts! On teardown I noticed a small hole in the exhaust. It's very hard to see in the pic, but the screw driver is in it. That was leaking for sure..
That new exhaust in the pic just came in Friday. I saw the bellows also had water in them. Then I saw water stains where it looked like it was entering in the transom. Needless to say I got to this in the nick of time. Things needed attention badly! So I'm making them all right :) It's a hard process, but I'm learning, and will do that much better next time.
I looked in the "kneeing". Not a bad idea.. My only concern is I'm very tight on space. I didn't notice the transom flexing, it's the above that made me do this. I do have that swim platform, and I think it helps with strength. I have thought about closing that 1 inch gap between the platform to help give it strength, but it will cut off access to the ladder screws.
The PB went ok. I didn't find a recipe, it seems like people are just making it until it gets to the right consistency. The first batch wasn't thick enought. I was using a drill bit mixer. I don't think it would have been good without it. the cabosil is hard to mix in, and it blows away easily. It's just so light and airy. The second batch was better but I put in too much chop strand, so it was hairy. Both batches should work ok, but they did need imporvement. I do agree, even with my rookie mistakes, I still feel this will be better than what it came with. I'll post pics next time I get the cover off the boat. The new transom is clamped in. I still need to put the last piece on, then on to tabing and laying the 1708 bi-ax.
Matstang
Here is the first piece that went up for the new transom. Went together good. I will say the peanut butter slowly squeezes out over time. I though I got it all wiped out and came back to more.. Hopefully it all holds.
My side pieces didn't go as close together as I'd like, but I think they will be ok. I filled in the gaps with peanut butter.
Next I'll lay another 1.5 oz matting, then soak the 2 pieces with resin and sandwich them together. I need to take a measurement, so far the layers that I've used going from the outside in are the outer fiberglass shell, peanut butter, fiberglass 1.5 oz, 3/8 plywood, fiberglass 1.5 oz, 3/8 plywood, fiberglass 1.5. Hopefully I'm good with the width requirement I had before I did all of this.
I do have a question for you guys. Next I'll peanut butter the gaps. After that do I lay the 1708 biax over everything first or the tabbing? I've never worked with the 1708, I'm curious to see how it compares to the 1.5 oz chopped strand mat I've been using.
Matstang
Here is a long winded post on where I am.
Second layer of plywood is down and clamped in.
Note to self, don't use the hole for the trim tabs to clamp. It was a huge PITA to get the screws out. I have no doubt in my mind that the resin is very stong and is more than capable of holding it all together.
I ran out of cabisol. I was so hung up on how much resin to order, I never really looked up how much cabosil to order. I got a 5quart bucket thinking that would be more than enough. Well, I was wrong. I go through that stuff like crazy. I ordered another 5 quart. I'm sure I'll have some left over, but at least I won't lose a weekend because I ran out! I finished my edging and put down the first layer of 1708 tabing.
Getting in this back corner area was a huge pain. The top area where the swim platform is came out prettty nice, I was really worried about it.
The second layer of tabing didn't go to well. I mis-judged the time and ran out of light. Finding the air bubbles in the dark doesn't work too well. I woke up the next day and saw the damage I did. I sanded most of the bubbles out, and gave it a layer of resin. It wasn't too bad, but not perfect. Anyway, after remembering pulling it apart, I'm sure it is still stronger than what the factory did. Here is the first layer of skining. This weekend it will get the second layer.
Matstang
And look, my engine looks like an engine again!
I still have a few little things to get for it, cap, rotor, wires, motor mount bolts. But it's pretty much done. It is EFI, and some wires had their insulation falling out leaving bare wire. I've replaced all of this. I want to start it outside the boat to make sure it runs. A lot easier for me to work on it outside the boat then inside :) I still have a lot to do, but I'm getting a lot closer to taking it back out on the water! I can't wait!
