96 lund tyee, 4.3 LX mercruiser. 0F294871.
i pulled motor out of boat 1 1/2 years ago, to rebuild boat. everything is reinstalled now, and i can’t get it to start. the outdrive is off, but i only want to fire it up and not run for any time. as far as i can tell the wiring is all correct and working. the motor ran fine before removal, and i just did compression check to ensure no stuck valves. the distributor was not removed from motor. i have checked the firing order numerous times!! i does seem like that is the problem, but i’ve checked and rechecked it over and over. i just tore carb apart, and it is perfect.
the motor turns over great, but i’m getting backfiring through the carb. fuel is new. tank was drained completely during rebuild, and filled with fresh fuel two days ago. carb had good fuel in it when i tore it open. spark plugs are new and gapped correctly. any suggestions would be great as to where to go now.
