gcalvert83
Thread starter- Joined
- Jun 24, 2020
- 9
Read through a lot of the forums and didn’t find anything that compares to my issue. Things I have done to this motor include. New non oiling VRO style fuel pump, rebuilt primer solenoid, new diaphragm in vapor separator check valve, new spark plugs (champion QL78YC, gapped to .034) fresh fuel/oil mix. Has good compression and spark. Rebuilt and cleaned all 6 carburetors. Now for what I have going on, took the boat to the shop for an assessment because I’m thinking about selling it but I want it to run correctly before I do. Top left carb as you are looking at the front of the engine was leaking fuel out of the overflow tube so I authorized another rebuild on that carb. Got it home, put the new plugs and fresh 91 non ethanol gas and oil in. Put muffs on, started it up and gas is coming out of that overflow again! Took carb off, took bowl off, everything seems in order, adjusted the float only slightly. Reassembled start it up and the same. All the other carbs appear to be functioning correctly. Motor is running rough, obviously that one cylinder is flooding out. What am I missing? I’m at my wits end with that one carburetor! Thanks in advance for any input.
