96 force 40 hp lower unit help
ericspainter
Ok let me thank you for your help first off.My questions are were does the water come out to let you no the water pump is working.Every outher outboard i have had has a little hole on the cowling it comes out of and this one doesnt.A little water comes out the back exhoust holes but very little.Is that were it is suppost to come out?I can see a little hole in middle of this but not sure if it is a exoust hole or not.I thought exhoust came out prop.
Ok i orderd a water pump repair kit and i need to no how to remove the lower unit .i now the shaft is splined but how do i get the shifter linkage broke loose.Any tips or tricks i need to now for my first lower unit removal.
I just got this boat and it idles good but i tried to take it out and it woulded go like it was boged down.I put my hand over carb while on water and in gear and it bout threw me out of the boat lol.I removed the carb to find it had had gas in it from five years off setting.I also orded new parts for that but i can handle the card just need help on the water and lower unit removal.thanks for your help ,Eric
jerryjerry05
Re: 96 force 40 hp lower unit help
Some people do this some don't.Put it in forward gear.That way when the unit is put back on you can use the prop to turn the shaft to engage the splines.Only pull up on the prop.Pushing down won't do anything.
Remove the screws 5, I think.
See pic.You should replace 16/17 and make sure 11/18 aren't worn too bad.
Reassemble with grease on the splines of the pump and inside the housing#11
and #33/24 grease on the splines.
While your buying parts get a fuel pump rebuild kit.Then replace the hoses from the tank to the motor.Ethanol is messing with a lot on outboards.
You can install a pee tube.See pic,powerhead #19 has a small hole that you can get a fitting and install a hose.
Good luck.J
ericspainter
Thanks alot man.were is that power head part on the motor that your refering to to put the water fitting?.Might sound dumb i dnt no lol.and on the three little holes on back is that normale for some water and exhoust to come out there?Ya after i orderd parts i thought i should have orderd a repair kit for fuel pump to.I need to get that last thing i want is trol back 6 miles lol.thanks for your help and ill be sure to reply back with my results.
O wait is that # 34 the front of the reeds right behind carb then?
jerryjerry05
Where the spark plugs go_On top.
Yes 3 little holes it's ok for the water to come out there.
MOst exhaust comes through the prop.
Go to boats.net and look up this site: Mercury Force Outboard Parts 40 H.P. (1996) 0E138600 THRU 0E202999 CYLINDER BLOCK ASSEMBLY Diagram
You will see the head better.
It will have every thing in pictures you need to know.Explore this site,it ghas your motors parts diagrams.J
ericspainter
http://www.boats.net/parts/search/M...999/RECIRCULATION AND PRIME SYSTEM/parts.html
are u refering to #3 on this pic of the cylinder head.i found these on the motor and i think this is wat your talking about splicing a tube on for me to have the water shoot out.if so i can put a t where # 2 is if the t and 90 have same threads.will there be any negative affects towards cooling if i do this?
ericspainter
Ok well today i got home and decided to remove the lower unit.First i changed my gear lube b/c it hasnt been changed in five years.well old oil came out looking good with minamil meatal shavings on the magnetic bolt.Replaced lube and begain taking out bolts to remove lower unit.I found the shift lever to be visable on back side with a nut and another nut to take tension off the outher nut.After removing all bolt it poped right out.Ok total time including changing lube maybe 30 min and this was first time.i kinda laughed and thought they realy want 200 bucks to do this.My parts for water pump arnt coming till next wek sometime and when they do i will update on how well it goes back together.
