96' 90 hp mercury will die in idle
glmy787
Hello, my name is garrett. My 90 hp Mercury outboard sat for 3 years barley being ran. Now i have used it 4 times this summer, and it runs well when its driving but when i first start it i have to rev up the rpm high to get the engine started. It doesnt sound good for the engine. Then when i put the rpm back down to shift the boat into gear the engine usually dies. I greased the zurts, changed spark plugs, and put in new 93 octane fuel to mix with the gas that was left in it from last year. That gas mix is almost gone. I'm hoping after running the boat once a week this summer and continuing to use sea foam i will be able to start the boat without having to rev it up. Or maybe when boats get older they dont start well. Any advice or tips that anyone could give me on starting the boat or anything i can do to help it run would be much appreciated.
James R
Re: 96' 90 hp mercury will die in idle
Going to have to strip the carbs and clean them. Rebuild with new kits. When you get the beast up to run be sure to use Stabil in the fuel or you will be back to doing it again. A water trap filter is a must to prevent failure due to the water in our crappy gas. Never use anything other than 87 Octane fuel. You can burn the motor up with 93.
Remember 6 gallons of good gas mixed with 6 gallons of bad gas gives you 12 gallons of bad gas. Drain the tank and start fresh.
