clemsonfor
- Sep 19, 2005
- 1,011
Re: 95 Johnson 150 carb leak?
another thing dont ever run a motor higher than a high idle say 1200 rpms it will get away form you and run even after the ignition is off trust me i reved mine and it got away and i had to choke it and pull the fuel line to stop it. Plus you can blow it with no load on the motor. On muffs it only needs to be idled only run WOT while on the water in foward, not even in idle.
