95 four wins candia stringer replacement
Nfandrich95
I have a 95 four winns that I have recently found stringers bad, I don't wanna spend the 5k to have it done so I'm going to do it myself. But I have not done this before so I'm just asking for a little guidance on where to start at
rad1026
So much information here. Grab a cold one and start reading. Throw some pictures at us.
Nfandrich95
I'll upload some pics tonight. Just wondering where to start, on removing the stringers, do I cut he top of the fiberbglass off and put the stringer out like that or do I cut the fiberglass at the hull and just remove the whole thing? And can you just replace the bad section of stringer or do I have to replace the entire stringer
kcassells
Pics, pics pics,,,, welcome onboard. You may have to pull the cap.
tpenfield
On the traditional designed boats you cut the cockpit sole to expose the stringers and bulkheads. whatever you do, do not cut the hull . . . that would be bad.
On the newer design (2-piece, clam shell) boats, it is a different story. that's why some detail and perspective pictures will help us see what type of boat design/construction you have and any obvious signs of deterioration.
Take a look at the many threads on here and you will see the steps that others in your situation have gone through. . . most are of the older 'traditional' design where the cockpit sole runs right to the hull side. there have not been too many of the newer 2-piece 'clam shell' design.
Since your boat is a 1995, it may be either design, so it is best to know which one it is first.
