95 150 ocean pro dont crank
crazy charlie
I went to turn over my 1995 150 hp ocean pro for the first time this year and I got a few cranks but the battery was low so I charged the battery and turned the key and nothing.Not a sound.I checked the shifter and battery wiring .removed the motor cover and checked the fuse along side the starter and p pack.the fuse was all aweful and the holder was bad too.where should I go to replace the fuse holder and what size fuse goes there?? I guess this was the probable cause of the dead ignition.Can I connect the fuse wires to jump it to see if I get a crank??? Thanks Charlie
crazy charlie
Re: 95 150 ocean pro dont crank
Not lookin to burn anything up for sure.Just thought jumping the fuse to see if I get a crank would give me a little direction to start looking in.I never had absolutely nothing happen when I turn the key.BTW the tilt was working fine so there was power going to something.
