FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i have changed my trim system to a 2 wire from a 3 wire but cause of the pump change i dont know where the hydraulic lines go here is a rough diagram and i mean rough but basic could u just place number w letter would help thanks
why would you do that? there is no wiring harness to support 3w in a '94 force. and that particular pump was not intended to work with the smaller reservoir found on a 3w. you should quit while you're ahead and go back to 2w.
i dont think u read this right or i didnt explain well i had a 1987 3 wire set up and the pump was shot so i put a two wire pump on with new harness that i picked up for cheap from my mechanic so im told there is nothing different about it other then the wiring hense the new harness and that the hydraulic lines go on the bottom which is done and works great but i just want to make sure the hydraulic lines are correct
i agree i just havent put it in the water and the guy i bought the boat from said he couldnt trim up underload and i am wondering if i have fixed the problem or should i be looking into the o rings in the trim cylinder ?
if you started off with 1987 3w then you started off with ND30 fluid and your trim rings should be fine. when the trim rings blow out it is usually from the factory ATF used 1992-1994. If your trim ring is blown the system usually can't even lift. If it does lift then it drops like a stone when you let go of button. I hope you didn't use bundy brake lines.
