FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have 1994 90 hp yamaha oil injected with no oil tank what would happen to the lower and upper bearings if i premixwd the gas would i be ok or should i look for a oil system
well try and find a system in the meantime, otherwise if you can just take the oil pump off and take the shaft out that connect the oil pump put it back together and block off the pipes by folding them in half and tying it well with some cable ties or a small hose clamp ...... hope it makes sense .... was a long day
