94 4.3l lost compression 1-3-5
How to fix
  • Remove head
    Votes: 0 0.0%
  • Just install low mile truck engine
    Votes: 0 0.0%
  • Total voters
MIFUN3
Hi guys quick topic, need help .
Only had a few minutes to check but found no compression on 1-3-5 Checked with bore cameras valves are opening and closing, head gasket? Have access to a clean 94 silverado 1500 4.3 engine ??? Suggestions ?
havoc_squad
Did you do a leak down test yet?
That's going to tell you quickly where the direction of the air force is primarily going (head gasket, lower end, head/valves)
Don't take the engine head off or more until you identify where the relevant leakage is coming from first using a leak down test.
alldodge
Blown head gasket, might be an easy fix with a valve job and flatness check on original motor. The 1500 motor would be a good swap
Lou C
Those engines are pretty easy to take apart and simple to repair, I had to use an impact gun to get the cyl head bolts out because of raw water cooling in the salt water. I would do a leak down test first. You can still get reman heads for the pre vortec heads, or get yours redone if they just need to be magnafluxed checked for flatness & a valve job.
