I purchased a 92 Johnson 40 VRO. Disconnected the VRO and run 50:1 via local dealer. This motor won't start. It wants to but it won't idle. If I push the plunger and keep it revved I can get it going. It runs great at slow and faster speeds. It just wont start and idle. I suspect carbs. Looking for any suggestions. If there was a tank problem, I would assume it would be there at all speeds. Maybe I'm incorrect. It pumps up fine. I have a plastic tank and keep the cap on tight. Is there a low speed idle that could be causing this? I have not taken the carbs apart.
Tom
Tom
