RatherBFishing
Thread starter- Joined
- Sep 11, 2003
- 39
A couple months ago I purchased a '91 Procraft 200 Pro. bass boat with a Mariner 2.5 liter 200hp. The seller said he had it out only once ever and had it about a year. He said he was able to get up to 70mph. I am only able to get up to about 55 or so per the speedometer, about 47 per gps. I guess that would be problem #1. #2, I am having a terrible time getting it up on plane. Even trimmed all the way down, the bow goes up in the air and about the time I start getting a little speed, the prop starts cavitating and I have to back off the gas. Once it does get on plane, it stays there and performs pretty well as long as I keep the speed up. It seems to drop out of plane at about 18 mph though and I would think it would stay on plane slower than that. <br /><br />The engine doesn't seem to dog or anything, but problem #3 is that it idles really bad. It kinda "chugs". Nothing smooth about it. It starts well but when it does it puts out a cloud of smoke for a few seconds. <br /><br />Finally, problem #4 is that just today, for the first time I noticed oil dripping from a hole in the lower unit. I assume the hole is a water in-take, but it is in the front of the lower unit rather than the side.<br /><br />Obviously, I am new to boats. By reading through some of the forums here, I suspect the motor may be too low and the exhaust is in the water causing the bad idle and possibly the smoke. It does seem really low to me. Standing still, the top part of the motor is practically sitting in the water, way over the exhaust.<br /><br />I'm not sure what to do about getting it up on plane. I here talk of the "motor being x number of inches below or above things" but I don't recognize those terms.<br /><br />Is it possible all my woes would be solved by raising the motor or getting a jack plate? Could that even be the cause of the oil?<br /><br />Also, what should the max RPMs be on this motor? I don't want to over rev it.<br /><br />Thanks!<br />Mike
