91 johnson 25 hp carb compatible with 98 omc carb?
DougyB
Title says it all, I have a 98 25hp omc carb I was wondering if it would work with my 91 johnson 25 hp. Having a backup would be nice for changing at the dock, I drive to far to fish just to turn around and go home because of a carb problem. I do everything necessary to prevent it, but just in case...
boobie
Re: 91 johnson 25 hp carb compatible with 98 omc carb?
Go to shop.evinrude.com and look up both carbs. They have good diagrams.
DougyB
I already have the omc carb off a blown engine I didnt see anything on evenrude that inSure
d they are compatible
AlTn
are the parts no.'s the same for both?...if so..same carb
DougyB
Part no. is completely different yet the carb fits perfect- hoses, lines, throttle linkage mounting bolts everything
AlTn
98 they offered the 3 cylinder 25 hp. as well...look for a carb that resembles yours and compare orfice jet no's, carb kit no's, etc...do any of the 98's internal's match your 91?..marineengine.com has diagrams and part no's
DougyB
Thank you gentlemen, found that the jets are different for slow and high speed, no match, appreciate the guidance
