mickab
Thread starter- Joined
- Mar 5, 2012
- 53
i have a johnson 225 vro 91 model and i have a few issues, first at an idle i have a dead miss in the motor and it sometimes kills the engine. the second is when first started and taking off it runs just fine but around 4000rpms it starts to surge like it running out of fuel. but it will run good under 4000rpms about 45 mph. when i stop and fish awhile and go to take off again the motor starts just fine(with the miss still) but i can dig into the throttle cuse it seems to be starving for fuel but if i run it just above idle for 5 min or so it will finally take off and run great up to 4000rpms. so i figure it a fuel problem but not sure of what else it could be. the only thing i have done so far is replace the fuel line from the tank to the fuel pump. with no change. ive drained and cleaned the fuel tank and filled with fresh fuel. so now back to the drawing board. any help with this would be very welcomed.
