littledragon
Thread starter- Joined
- Jun 16, 2009
- 3
Hello!
I have the 1991-92 model 150hp US Marine Force engine. This engine does not have the info plate located near the carbs, but the engine stamp and little alloy plate is on the (electric mounting array side, where the tach, temp, mag array) and that plate reads JAN 98.
Used motor, installed, roasted the voltage regulator by how I had the wires hooked up. I confirmed after another 3 hours research, while I wait for a factory manual, that I have trouble with only 2 wires. MAG white and MAG blue.
The engine wiring diagram from the book shows "ENG STOP" and "BAT CHARGE. "The "engine stop" post runs to the opposite side of the engine to the electrical cluster. The "battery charge" post runs towards the coil so to speak, where the starter, battery, and red wires are.
1 mag wire goes to engine kill, 1 mag wire goes to battery charge, correct?
