Duckhunter71
Thread starter- Joined
- Jul 31, 2008
- 17
Picked up a used 90hp Mariner. It is from the early 90s (OD163,,,).
Compression is good and even across all three cylinders
Starts up good,
Runs great on Muffs including in gear.
Mounted it on a boat, took it to the ramp to do a on the trailer test.
Started, pumped water, shifted fine.
Went two-thirds throttle in the water. got a knock. It is a dull knock, not one that sounds like a rod is going into orbit.
With the compression even and good, is it a bearing problem?
What do I need to focus on before the tear down.....
Starts up good,
