ssportsmfg
- Oct 7, 2014
- 42
I just replaced the water pump completely on my 2001 50 hp Johnson, on mine the shifter rod is to be in neutral (go figure). I also got a lower unit reseal kit, and wouldn't you know it they put the wrong size o ring in for the outside of the nylon shift rod holder. The O ring for the shaft itself was ok,
There are simple solutions for these things; that I fail to see why after all these years of making outboard motors that you would have to drop the lower cowling off the motor, take the inserts and lines out of the cowling and take the tiny pin out of the linkage to drop the lower unit. Just plain stupid. There is no reason why a simple spline cut on the shifter shaft along with a sleeve with matching splines can't be used other than it might cost a couple of dollars more to do. At least my Johnson had the cast in water passage and not the dumb assed Mariner tube.
With outboards it seems that there is always something. Like haveing to have special pullers to replace the shaft seals instead of de
Last year I did a water pump on a Mariner and it had a dumber than snot copper water tube that you had to line up with a rubber sleeve, the shifter shaft, and the drive shaft all to line up at once.
