90hp Johnson, having trouble removing lower unit.
mikeacs
Attempting to do a little pre-season maintenance on my 99 Johnson 90 HP, and cannot get the lower unit to fully drop for water pump replacement. According to the info I have, I should simply be able to pull the retaining pin #49 on the shift shaft #50 , and push the pin in toward the powerhead to release the shift rod and allow the lower unit to drop. The unit drops about 1.5" but no further. I also had my son hold the shift rod in while I wiggled the lower unit as someone else suggested...but no luck. I've always done my own waterpump service on my 225 Yamaha 4 stroke and other older outboards, and have never had a problem removing the L/U. I'd appreciate any help or suggestions as to what I'm doing wrong.
1nebel0
You are correct...The only thing holding the lower unit on is the bolts and that pain in the _ _ _ pin.. If you have all the bolts out and it sounds like you do since it is dropping the pin has to still be holding the shift rod.. Mercury has Johnson beat hands down when it comes to lowering and installing lower units..That doesn't mean that Mercury has got it's problems..LOL...
bonz_d
Could be that the shift rod is hanging up on the rubber grommet in the lower cowl pan. If it's dropped 1.5" already it should pull out.
mikeacs
Thanks for the replies...Someone told me today that there is an inspection plate on the side of the housing with a second point to disconnect the shift rod. I don't remember seeing this, but I'll find out this afternoon. I am tempted to put a little more force on it (pry) after it separates the 1.5", but don't want to damage the shift rod or worse. After fighting this for two hours to do a 10 minute water pump swap, I'm ready to get this over with..
mikeacs
Ah, I thought I would have noticed the plate if there had been one. Had a feeling that was a bust...oh well..back to pushing the pin, and wresting the lower unit.
bob johnson
have you tried turning the prop either way while pulling down?? ... you should be in forward,..... that is where you need to be to removed the lower unit!!?? you maybe hanging up on the splines in the power head...
bob
mikeacs
No Bob, haven't tried turning the prop, and I was told to have it in reverse rather than forward...Guess I could give that a try also, thanks...
Mike
Honorary Supreme Mariner
No need to be in forward and absolutely no need to turn the prop.--Gently use a prybar and it should come down !
bob johnson
(1997)Manual says:
(1)Removed air silencer, rotate propshaft and shift the gearcase into FORWARD ( highlight from the book!!), removed shift rod retaining pin
(2) push shift rod link toward powerhead to disengage shift rod.
black and white
good luck OP!!!!!!!
bob
mikeacs
Thanks!!..I'll tackle it again tonight....One way or another, its gotta come off!
mikeacs
Many thanks! ....FORWARD was the key...a few twist of the lower unit and it almost fell on my foot. THe amazing thing is after 7 years the water pump still looks great...will be changed anyway of course....
bonz_d
Glad to hear you got it off. Now all you need to do is remember how for the next time! Enjoy.
mikeacs
As always..one thing leads to another, and I've noticed that the shift rod is way to hard to move, meaning the o-rings need to be replaced in the shift rod cover. There are two, I am assuming I can carefully fold and feed the new o-rings into the housing?...Also although I did count the turns when un-threading the shift rod, If someone has the exact measurement for re-installation, I'd love to be able to verify the correct height.
Thanks again for the help in getting this job done.
The o-rings are easy to put in there.-----Where shafts turning when you were trying to shift it on the workbench ?---I think shaft heights were posted here just the other day and may also be in the top secret files top of the page.
bob johnson
what model is your motor... if I remember right they stopped making the crossflows in 98...I think
I don't think the fitchthcht motors had any different lower units... so id guess your shoft rod length is 21-1/4 for a 20", and 26-1/4" for a 25....( don't know what you have)
mikeacs
Thanks again Bob, engine is a 1999, short shaft I'm sure since its on my bass boat. The shift rod was very tough to move in an out on the lower unit. I had thought I had a shift cable problem at first..I counting five turns when removing the shift rod, so I am pretty close on adjustment, but it's always better to be sure.
bob johnson
1999 is the year...not the model..... short shaft motors are 15"....long shaft motors are 20", extra long are 25" and extra extra long are 30".......don't know why or what they call the 22.5" shafts lengths!!!!!!!!
I doubt they ever made a short shaft v4 in the 90's.
the shift rod movement might be hinderd by damage inside the lower unit!!
bob
mikeacs
Bob, installed the new o rings and the rod moves easily now. I'm showing 21 1/4 in neutral which would be correct for a long shaft, measured from the flange that the rod cover bolts to on the lower.....(surprised by the long shaft, figuring a bass hull would need a short shaft) I think I'm good for reassembly now, provided I can get the shift rod and release pin to cooperate. Thanks once again for you quick replies and info..
