90hp brownband merc
jamiebrant
i just bought a brownband mercury 90hp inline 6 for my 16ft runabout.motor looks to be in vgc but in sayin this what are these engines like reliability wise and do they have wiring issues or what are common problems that happen and how to tell this .i just want to sort out any issues before i take it out there and find out the hard way.
cheers
Chris1956
Honorary Supreme Mariner
Re: 90hp brownband merc
Those motors are a classic, successful design. If it were me, I would inspect the carbs to make sure they are clean, inspect the wiring to make sure it is good, inspect the gearcase for leaks and chnage the gearoil and replace the waterpump impeller, wearplate and gaskets. Now check link and synch
arsenalpsu
Also do a compression test, should be +/- 10-15% of eachother
Cadwelder
I've ran a 1987 In line 115 since it was new, it's been an extremely dependable engine. Only things that have been replaced in 23 years is a stator and fuel pump,and a couple of rectifiers, other than normal maintenace. That's a pretty darn good record in my book.
bktheking
Brownband with oil injection? The only thing I've been told is disconnect the inj and run mix.
redjmp
I totally agree!
Also they don't like being lugged so make sure you prop it so that it hits at least 5500 wot and try not to run too long under 3000rpm.
But don't run it at wot for too long. It will run forever at 4200.
My '86 115 gets a best cruise @ 3150 @2.45 l/km at 44 km/h. 2.2km/l @ 4200.
jamiebrant
hey thanks heaps for that i was shown compression 125psi with a 5psi variation beetween 3 cyl and everything else is ok besides one wire for the til trim i was a bit worried at first because a couple of people have told me that they are aspirins (they dissolve in water) from corrosion and you will have nothing but trouble. Now im thinking differently.ill post some pics soon from Australia
cheers
zac1954*1
I also have a 90hp brownband merc serial no A701650. Can anyone tell me when in the
'80s it was manufactured?
Gomer50
Now I run a 1978 90hp inline 6 and according to the book these motor run between 4500 rpm and 5000 rpm not sure if that was changed in the 1980's dont want to over rev,. her.
