90 Merc Low Compression #2
hsi111
Ok, here's the deal. I bought a boat a couple months ago and got screwed because i did not know to check compression on 2000 90elpto. Making a long story short, It actually ran when I looked at it but when I got it home and tinkered with it, it had 0 compression on #2. Pulled side plate an saw mangled rings. I haven't torn it down further and do not know if cylinder walls are damaged. Today I found a complete 2003 90elpto on CL for $1500 that looked real nice. I offered him a thousand and said he would sell it for that. Seller said it has been sitting up a couple years but ran great. Now that I am a couple of months older and a hell of a lot wiser, I took a battery and my compression tester. Guess what? It had 120psi on 1 and 3 and 30psi on #2. I ended up buying it anyway for $300. It is absolutely complete even with shift cables. Now my thinking is that 30psi might just be bad rings and it might be a better rebuild project. Questions are: Is there something about #2 cyls on these motors that go bad or is it just a coincidence. Is there anything other than rings that could cause low compression? Anything else to check before I try my hand at rebuilding it. I have rebuilt car motors but never touched a boat motor. Thanks, Rick
carholme
Re: 90 Merc Low Compression #2
Rick;
Could be a failure of the oil injection systems, broken rings, etc. Whatever, with your experience building motors, you should not have a problem doing the work yourself. If you provide the s/n for both engines, I will get you the parts lists and see if I have the service manuals which I can send you.
Good deal on the last engine, especially with the controls.
Gerry
hsi111
Thanks for your offer Gerry. Serial for 2000 model is 0T072541 and the 2003 is 0T663974. I think the motors are identical.
Rick
carholme
Rick:
2000 model comes up as:
MERCURY - ( 90 H.P. (2000 ))
Serial No: 0T072541 Model No: 1090412WD
Parts and Service Bulletin list for s/n 0T072541:
Search Results - Crowley Marine
2003 model comes up as:
MERCURY - ( 90 H.P. (2003 ))
Serial No: 0T663974 Model No: 1090412AD
Parts and service Bulletin list for s/n 0T663974:
Both engines use the same parts list and service manual which is 90-830234. If you send me a PM with an email address, I will send you the manual.
Gerry
hsi111
Gerry, Thanks for all the info. Will be a big help.
hsi111
Is there a way to do a leak down test or other test to rule out head gasket damage on the motor that has 30psi on middle cylinder?
