90 hp force outboard motor
jcrook35
i have a 1990 bayliner capri with a 90 hp outboard motor and i took it in to get it winterized. they called me and said that there was water in the lowerend where there should oil and that there needed to be a gasket kit done on it and that would cost 350 to 400. anything i should ask them or know to look for or even if i could do it myself!
pnwboat
Re: 90 hp force outboard motor
Did my 125 HP lower unit myself. Manual from E-Bay= $28.00. Lower unit seal kit=$45.00. About an hour and a half of my time. No more water leak.
Note: Check the gaskets on the "Fill" and "Vent" screws on the lower unit. It's not uncommon for them to leak. Gaskets are about .50 cents each.
Regardless of which it is, I definitely wouldn't pay $350 - $400.
jerryjerry05
Ask what seal is leaking.Fill out the profile you might be close to someone who has a pressure tester.
Where is bennet?
It could be just the fill gasket,the drain seal.Something easy.
But 350 is steep.J
jcrook35
ok thank you i live on birch st in bennet but the boat is getting fix in lincoln! they said that the it would take 3 hours to reseal the lowerend $60 for the kit!
milehighboater
I think he was meaning which state is Bennet in?
jcrook35
so they tested the lowerend and said that it needs to be resealed. so i was thinkin about doing it myself but i dont know anything about outboard motors, so anything would help websites, instruction or anything! thanks!!
jerryjerry05
You could probbaly do it yourself.But you need a pressure tester.You might not need a complete rebuild.
Without the right tools,your wasting time and $$$.
The drain plug on a lot of Forces leak. Nothing can be done about it.J
