90 horse slipping
keckster
03 mercury 90hp acts like it is slipping out of gear around 2200 rpm. it will go about 7 mph without noise or slipping but once i go over 2200rpm it revs up really high and has no forward thrust. would love to hear if anyone has any ideas.
saumon
Re: 90 horse slipping
use the search function for ?spun hub?
really easy to find out with a permanent marker or simply try another prop. But, with what you describe, i'm almost sure.
keckster
mine is a solid hub not a two piece. if i had spun the hub would it still push the boat at 10mph?
saumon
yes, past 10mph the rubber loose its ?grip?. Simply try a spare prop if you have one or, with your current prop, draw a line with a permanent marker, put some ?liquid paper? or make a small groove with a chisel, whatever you want, on the inner AND outer part of the hub. Try it on the water and recheck if the two marks are still aligned.
saumon
this rubber core act as a shock absorber
keckster
there is no rubber core. it is a stainless steel solid prop. when i turn the prop with motor in gear i can feel the pistons moving.
Jeep Man
It has either a rubber insert or a shear pin (old). Borrow a prop if you don't have one and give it a try, before spend money on other repairs
saumon
As he said, i've never heard or saw a solid core consumer use prop. They may exist for very specialized applications like racing but i'm pretty sure that's not your case.
keckster
your right guys. took the prop off and it looks as though it has spun out. talked to the prop guy and i'm taking it to him tomorrow to get it fixed.
thanks for all your help. hopefully i can be of assistance in the future .
Texasmark
No such critter as a solid hub unless you are using a high performance cleaver type prop with water over the blade which is made to accept a couple hundred hp and run 90 + mph.
Either you have a plastic/bronze/brass removable hub, recent invention, or the old style (which you can't see from the outside) rubber insert slip hub.....with the brass/bronze spline to slide onto the prop.
Now that we understand each other, what do you have......Oh, the Avatar of mine is my '02 90 in action @ 50+ mph running the latter, before E10 was the only fuel available around here.
Mark
keckster
i have the old style. bought the prop used. but my prop guy says he warranties them so i just need to bring it by.
