90 bayliner capri info
bandit32ca
im looking at buying a 90 bayliner capri 17 ft with a 3.0 l 135 hp mercruiser and was wondering what the top speed is and how they are for power. for pulling tubes... im trying to compare it to the boat i have now a 84 mod trihull 16ft with a 115 merc on it... will i be disapointed in the bayliner..thanks for the info..
Rob454
Re: 90 bayliner capri info
Top speed Id say 38 give or take a few miles. As for pulling tow tubes You shouldnt have any problems but if the boat is full of people and then you try to tow youll wish for a bigger motor. If its you a wife and a couple of kids youll be fine. pulling a skier would be a little harder cause youll have more resistance initially trying to pull a skier specially if the guy is big he may even pull the stern out when he cuts back.
Rob
Bigprairie1
Top speed?
...well I'd guess something just over 40mph...maybe up to 43mph-ish.
I've got a 1990 18' Capri w/ a 90hp Force outboard and I'm good for 38-39mph on mine....so with a few more horses you should top that.
Before you buy tho'....do a compression test....look for even readings, no big drops.
Good luck
