Lee McLean
Thread starter- Joined
- Sep 10, 2011
- 2
I have a 2 stroke 90 Johnson 2003 model. When I put it in the water the engine on idling will not run smooth and then will cut off. When I crack it back up it cracks fine but I have to give it some gas to get it going and not cut off on me. If I run the engine hard for 5 or 10 minutes and then go to idling speed it does just fine. It runs great, but when I cut the engine off and let it set for 30 minutes or so and start it back up it we are back to square one again. (Cutting off at idling speed and have to give it alot of gas for it to run. I did have my boat machanic look at it and we replaced the hoses, bulb, water pump and themostates. After replaceing the water pump it doesn't push out as much of water as it did before we replaced the water pump. Is this common for this type of engine.
Any suggestions on what might be wrong with the at idling speed would be appreciated. The engine doesn't stop at idling when I have the ear muffs on it in my driveway. Thanks for any help in advance.
Lee
Lee
