Jerry_NJ
Thread starter- Joined
- Aug 23, 2010
- 250
I pulled the lower unit on my 1990 (est) 9.9 HP Yahama to check/change the impeller. When I tested it there was no "pee" stream coming out. The unit is very low hours in spite of it age.
The impeller looks excellent to me, soft/flexible and has a slight bend in the direction of rotation. The housing also appears like-new polished. Please click on the two pictures attached to get a good view of what I am talking about.
What could be the problem? I previously opened the engine cowling and blew through the hose connecting the coolant area to the "pee" hole. Air passed with no problem.
This engine takes water in from below the cavitation plate. There is nothing in that area that appears to be plugged. Not sure how to test, perhaps I can just put the lower unit in a tub of water and see if water come up into the impeller chamber - any ideas?
