DeanHensler
- Feb 14, 2013
- 82
Re: 9.9 Evinrude, won't go over 3000 RPM
This motor does have an electric primer. I'm not sure how that relates to a "quick start funciton". You push in on the key to prime it. Once the motor is warm I never have to use the primer to start it.
I think the next step is to take the carb back off (which is a major pain in the *** on this motor) and do the blow test on the fuel inlet to make sure the needle and seat and float are working properly.
If that all checks out, the ONLY thing I can think of would be the electric primer being screwed up and flooding out the engine. This carb has two fuel inlets. I'm assuming one is coming off the fuel pump and that's the main line into the float bowl, the other is a smaller line in. Is the smaller line in coming from the electric primer? If I disconnect that and cap it off should the motor still run?
