Re: 9.9 carb adjustment
I,ve tried to adjust idle down per link that was posted and it still wont go down to a low speed for trolling. Ive pulled carberator off and cleaned it with carb cleaner and reinstalled. The motor will idle down with choke closed about 3/4s but it still idles fairly fast. As it start to die and I pull choke and it stay running then open back up and it will only run for a minut or so. When you rebuild carberator what do you change other than neddle and seat, jet, gaskets. Seem to be a simple carb with not to many internal parts. I have checked to make sure that the fuel pump is working at low RPMs. Any response will be much appriciated. Anybody out there have any similar problems?
