csadamsrep
Thread starter- Joined
- Apr 20, 2010
- 6
I have a Pro Line 241 WA that weighs somewhat over 5,000 lbs. when loaded.
I have a 2006 Mercury 9.9 Big Foot Pro Kicker mounted on the a metal bracked right to the factory swim platform. At idle ( 600-700rpm) the 9.9 will not even push the boat a half of a mile per hour in calm wind/sea conditions. I troll mostly for lake trout on Lake Superior at 1.7 to 2.4mph depending on various conditions. Occassionally I will troll for salmon from 3.5 to 5mph, but I would use the main 250h.p. io for that in most cases, but in some cases might want to use the 9.9 for that trolling.
I find that when I am even trolling for lake trout at modest speeds the 9.9 is probably running faster than it needs to. But also when using the 9.9 as an emergencey back up kicker, it is a bit slower than I want it to be under any siginficant headwind conditions. At 5000-6000 RPM, which is WOT, it will push my boat about 6mph.
In a fairly steady 25 mph headwind, it will barely push the boat 1mph, or so. I encountered a wind condition last fall like this and it took me a long time to get back to port. I know that this is a significant headwind to be trying to head into. I could have traveled down or side wind to reach shore, but did not want to beach the boat on rocks. But, my kicking speed performance is secondary to my need for faster trollin ability at lower engine RPM. A somwhat faster kicking speed performance would be nice to have as a byproduct of tweaking the prop for trolling.
The factory aluminum prop is fairly flat at a 10" dia, with a 7" pitch. I would like to increase my speed(distance traveled) by at least 30 to 40%. My marine mechanic says he has a Mercury outboard prop that may fit my boat that I could try, and it will increase the size of the dia. to 10 3/8", with a 9.5" pitch. This will cause the boat to travel an addtional 2.5 inches per prop revolution, he claims, which is a little more than 25% of an increase in distance traveled per revolution, which directly results to the same relative increase in speed.
Like I mentioned earlier, I may want to have a little more increase in speed, whether it be for kicking me back quickly from bad weather should my main engine die, or just for running the engine RPM a little slower when I am trolling for lake trout. Even if I doubled my distance traveled per prop revolution, I think I could even troll for walleye at 1mph or less, as the boat may go .4 mph now at idle according to my estimates.
The question is, how much should I reasonably bump up my pitch to have a resultant longer distance traveled per revolution in my application? What are the negatives of increasing by 25%, 35%, or up to 50% or more my effective distance traveled per revolution with this high thrust 9.9 motor. I believe the gearing on this 9.9 Big Foot was oriented toward helping lighter/smaller boats achieve slow trolling speeds needed for walleye trolling. It is good at that, but too good/slow for my application.
I have priced the large 15h.p. Mercury Big Foot and it is in the high 3,000 dollar range. I would like to avoid buying one if I can come up with a prop solution. The 9.9 seems to have gobs of torque and resultant thrust for my boat. I just feel that I need to gear it differently, and I hope that can be effectively done with the prop. Just need to know what the thresholds for neagative performance are when increasing distance traveled per revolution in my case.
A WOT speed in calm conditions of 8-9 mph would work well for me, which is at around 5500 rpm or more engine speed. I realize that as the speed increases to this 8-11 mph range the resistance to getting up on plane starts to exponentially increase at some point, thus causing the motor to work hard in pushing more and more water with the boat hull.
An RPM of around 1800 at 2.2 mph would work also sem to work well. At 1800 rpm now, I think I am probably only traveling 1.2 mph.
At 3000 rpm I think I might be traveling at 1.8-2mph. If anyone has any specific recommendations or feedback, I sure would appreciate hearing from you.
Thanks,
Clay Adams
Thanks,
Clay Adams
