9.8 evinrude kicker loses prime
biko
my kicker loses prime on hot summer days but runs good on cooler days. the 150 hp uses same fuel tank and runs fine. on the warm days kicker will loseprime every 5 to 10 minutes.
RCO
How is your fuel plumbed to the kicker? If it is tied in to the same line as your main outboard it should have a check valve or switching valve. You could try pinching off the fuel line to your big motor and running the kicker. If that solves the problem, it is drawing the fuel from the other motor then sucking air.
Honorary Supreme Mariner
Do you have a model # for the " 9.8 Evinrude " and does this motor stop running after 5 minutes ?
biko
RCO- kicker and main motor have separate fuel lines.
racerone- the model # is E10PX4AA. Yes every 5 to 10 mintes it will lose prime And it only loses prime if it is a hot day, like 22 degrees Celsius and above.
That would be a newer TOHATSU built motor I believe.--------Consult with dealer ?----Test run with cover off on a hot day.----The parts book shows an optional water cooling kit for the fuel pump.---Me thinks they are aware of a problem with these !
