9.5 1972 sportwin water not pumping
Globejs86
So I've been running my sportwin in a bucket after replacing the impeller. I was tuning the lean/rich needle trying to keep the smoke down and keep the plugs from looking too nasty. I had it sneezing then backed off about a half turn or so from there.
It starts up fine now. First try mostly, 3rd this morning.
It seemed quite smokey to me but I don't know what I'm looking for or what's normal. Yesterday I ran it a minute or two nonstop idling and it seemed to die down a bit.
The tell was sputtering water as soon as it started running at what I read was a normal rate. After it had ran I tested the water coming out with my hand and it got to the point I couldn't have my hand there anymore it was too hot. Again normal from what I read about thermostat regulated systems.
This morning I was running it and it was sputtering water as usual and smoke was a bit much, but then it just stopped. No more water coming out. Or maybe a drop or two of mist at most I couldn't tell between it and the bucket splashing and the smoke. But definitely not what it should be doing.
I started and stopped it a couple of times and revved it up to see if it would get it going again but nothing.
I took the lower unit off again and inside on the water pump was covered in dark Grey sludge,water and oil mixture. The impeller was still looking brand new and must have been working fine. I had polished the inside of the housing up to 2000 grit paper for an exceptionally smooth surface to keep the impeller from wearing out prematurely and to smooth out some of the pitting inside.
The thermostat I had checked before running it had looked very clean. No rust or anything like that. So I figured it's working too.
Why could the motor not be circulating water anymore?
I'm afraid to run it longer than 30 seconds at a time to avoid some sort of overheating issue.
Honorary Supreme Mariner
Your bucket is not big enuff.-----And water needs to be 6" above the pump too !!
Joe Reeves
You state that when removing the lower unit the second time the water pump contained dark gray sludge and oil.... check that lower unit for leakage.
As "racerone" states in not so many words..... that water pump is NOT self priming. It must be submerged in order to function. You obviously know where the pump is located.... the water level must be above that pump in order for it to operate.
Globejs86
No Title
That water is up to the lower bowl housing. It seems odd that it worked and now it doesn't. Why would it have worked at first and not now?
The water should be over the pivot? Seems deeper than it would be on the boat.
I'll try to find something taller.
Daveparm
If you didn't change the water in the bucket, the sludge in the pump is from the two stroke oil exhausted into it and sucked up into the pump. Does the pump smell like gear oil? As far as not circulating cooling water, you might want ot try and run it for 30seconds or so without the thermostat and see it you see water. if you do then you know it's on the powerhead side that has the issue. If not it could be powerhead or pump, or the associated pipes.
Joe Reeves
The water should be over the pivot? Seems deeper than it would be on the boat.I'll try to find something taller.
On the boat, in the water....... notice where the water is on the engine before you start it. When underway, the water is forced up and into the water pump by the forward motion.
Pivot? What pivot?... The water must be 3" or 4" above the joint where the lower unit bolts up to the long exhaust housing in order to submerge the water pump.
Use a large plastic trash can. Works for me.
You do have the rubber seal arangement that fits on top of the pump I hope.-----When we say that water must be above the pump we mean exactly that.----No fancy words required at all.
F_R
Or get it out of that bucket and on a boat on the lake where it was designed to run. That will cure the smoke and sludge issue also. It ain't a thermostat problem. There are two flow paths through that powerhead. Only one path is thermostat controlled. The other path flows regardless of thermostat status..
Globejs86
So maybe it had somehow been primed and the water went too low during operation and now it's not able to get water back into it until the water level is raised up a bit.
I'd love to go test it on the water. I just want to get the kinks out before I drive over an hour away only to have it not function properly and ruin the day.
Do you have the seal that goes on top of of the waterpump housing , yes or no ?
Joe Reeves
Understood.... Pick up a sizable plastic trash can to keep on hand just for the outboard test run. I have used one (the same one) for a one cylinder model up to the highest horsepower V6. Obviously you can't open the engine up to full throttle but for 99% of what you need to do... the trash can is the answer.
Globejs86
No Title
So here's what I've got in the water pump arena. There doesn't seem to be any seal on the top of the pump housing. Perhaps the impeller itself creates a seal inside. Is this what your talking about?
Globejs86
Oh yes there is a gasket that seats on the rim of the pump housing that the driveshaft goes through.
Not to be too stupid but I put it in more water and water was spitting out again
Simplest answer was the simplest solution. Thanks again. Sorry for being too dunce
F_R
No Title
Glad you got that solved. But next time (or for anybody else reading this) clean that crud off the surface that the stainless plate sits on and put some kind of gasket sealer there. The way it is in the picture is an invitation for exhaust gasses entering the pump intake (under the plate).
And apparently you do have the seal on top of the pump housing
BTW, the bearing housing under the pump plate in your picture looks badly corroded and deeply pitted. That thing is very thin and it won't take much more pitting to go clear through. When that happens, oil will spill out and water will go into the gearcase.
Globejs86
I'll look into a new housing soon.
Where did you get the photo from of the impeller housing? A manual?
