So I've been running my sportwin in a bucket after replacing the impeller. I was tuning the lean/rich needle trying to keep the smoke down and keep the plugs from looking too nasty. I had it sneezing then backed off about a half turn or so from there.
It starts up fine now. First try mostly, 3rd this morning.
It seemed quite smokey to me but I don't know what I'm looking for or what's normal. Yesterday I ran it a minute or two nonstop idling and it seemed to die down a bit.
The tell was sputtering water as soon as it started running at what I read was a normal rate. After it had ran I tested the water coming out with my hand and it got to the point I couldn't have my hand there anymore it was too hot. Again normal from what I read about thermostat regulated systems.
This morning I was running it and it was sputtering water as usual and smoke was a bit much, but then it just stopped. No more water coming out. Or maybe a drop or two of mist at most I couldn't tell between it and the bucket splashing and the smoke. But definitely not what it should be doing.
I started and stopped it a couple of times and revved it up to see if it would get it going again but nothing.
I took the lower unit off again and inside on the water pump was covered in dark Grey sludge,water and oil mixture. The impeller was still looking brand new and must have been working fine. I had polished the inside of the housing up to 2000 grit paper for an exceptionally smooth surface to keep the impeller from wearing out prematurely and to smooth out some of the pitting inside.
The thermostat I had checked before running it had looked very clean. No rust or anything like that. So I figured it's working too.
Why could the motor not be circulating water anymore?
I'm afraid to run it longer than 30 seconds at a time to avoid some sort of overheating issue.
