89'rude 150xp impeller ?
robertpage101
i just check the impeller on it and it was ok but there is water coming out of the crack where the lower unit splits and a hole pointing forward and is blowing out of area below, i guess there is like a tourqe mount on the the motor case that covers the shaft. is this ok the tell-tail is gettin water but it fells week. are the gaskets in the impeller housing bad they didnt look bad.
junior1113
Re: 89'rude 150xp impeller ?
they all do in the early 90s they put slits in where the lower unit meets mid-section
