89 volvo penta 230B identification
seizethecarp
This is my first boat some I am learning but here goes
After researching a bit I may have a frankenstien. I thought it was a 230B (engine code) but it has dual carbs. i need help identifying .... thoughts?
sqbtr
Re: 89 volvo penta 230B indetification
Probably a 151, look at the starter mounting boss there should be a tag there.
captmello
Someone may have swapped in an aq151 aka 250 engine. Looks like there are a couple 2x4s under the engine as well,..definitly not original.
Don S
The cast engine numbers (B230) is the Volvo block designation, not the Volvo Penta engine model number. Look on the flywheel cover where the starter bolts on, there should be a tag with the model and serial number of your motor. That tag in your middle picture is for the transom shield and doesn't have anything to do with the engine.
