skipper123
- May 17, 2010
- 74
Hi all, I have been reading restoration post on iboats for glass boats for about a year as well as two more boating forums for the last five years. Also built an FL14 from the bateau wood boat web sight for practice purposes and lost it due to mistakes in building process as in not putting cloth on both sidess of the plywood, not caping the edges of all the plywood with cloth and maybe from not using marine grade plywood as well, I used BC grade exterior plywood from HD box store and not getting it sealed 100% from moisture as in putting a few screws through the glass to mount deck hardware lights cleats ect. This spring I purchased a 89 sylvan deck boat that needs a transome and maybe stringer and deck replaced very soon. I have follwed the bule byu renamed overhulled rebuild beginning to end that guy is great. Some of the best looking work I have saw posted. After watching him and a few other rebuilds I got a little confused on some of the products and meterials used. It looks like some of the guys use poly and vinylester resin to glue the stringers and floor to the transom vinylester being the better resin. I got my material list togeather and called US Composites only to have my bubble busted by Steve who told me not to use anything other than epoxy for gluing and bonding. Did I miss what types of resin they were using from gluing and bonding stringers to the floor as well as to the transom. The FL14 I built was all epoxy so these issues did not come up. I dont want the transome to bust loose from the stringers under pressure or anything coming loose. Have any of you guys installed a transom and used poyester or vinylester. Also has any one removed the cap or part of the cap to replace the transom on this type of boat. The whole transom can be acessed from under the rear storage area but working in that hole looks like it would kill you. I thought about cutting the cap where it drops down on the side that would be a small cut about 6 inches on the inside and outside then remove the rear section to acess the transom. One of my big questions is can you apply wet on wet with all resins without the worry of blush or sanding between coats. I would like to stick with the facts and not guess at this rebuild.
