89 Mercury 150 Tune Up
cglover
I have a 1989 Mercury 150 outboard on my 18' Vision bass boat. I just recently purchased the boat and was wanting to Tune Upthe motor a little. I was wondering what all i should replace. I dont know a whole lot about the motor so i was going to start with plugs and plug wires. What else would be good to refresh?
Thanks
j_martin
Re: 89 Mercury 150 Tune Up
Thanks
Start with a compression test. With uneven compression, anything else you do will be useless.
If I were to "tune up" an unknown motor, I would do a compression test, replace plugs and wires if needed. Link and sync. Run a hard run with a full throttle cutoff with fresh plugs and then read the plugs to determine if carbs need attention. Obvious trouble like a miss, or fuel in the wrong place would be checked out, of course.
There really aren't any ignition components that wear. Plugs get dirty if idled a lot.
hope it helps
John
cglover
John
Thanks for the info. I know the motor runs pretty good, but some things look a little worn thats why i wanting to do some precautionary changes.
I will be sure to run some test.
j_martin
One part that can actually wear is the trigger harness right where it comes out of the trigger. If it gets to be pretty frayed, it's worth it to replace it with a better one before it drops 2 cylinders and makes you limp home. Used is fine. The triggers for 2.0-2.4-2.5 v6 are all the same.
If you go there, use proper tools, and pay close attention to screw condition, torque, and thread retention on the stator screws. If you're into tinkering, it's probably worth while to drill and thread 2 or 3 more holes in the stator mount. You can use either a centering punch or a brad point wood drill to reach down through the stator and mark for the holes.
hope it helps
John
