89 merc 5.0 lx with a 1.84 alpha one??
yrubugn
Didnt notice this when I bought the boat but the PO replaced the outdrive w/ a gen1 1/1.84...I see it should be 1/1.5
I have been battling a WOT surging issue and was wondering if this may be the cause?
Maybe I could just change props to counter the drive difference? Could I continue to use this safely?
The boat is a 21 foot cabin cruiser
TIA for any replies
yrubugn
Re: 89 merc 5.0 lx with a 1.84 alpha one??
Sorry please move to mercruiser...
TIA for any replies
Ayuh,... That ratio will cause Over-revin', but not surgin'.... That's usually a fuel delivery issue...
I kinda doubt you'll find a prop Big enough to fix the ratio issue...
yrubugn
So to bring rpms down I would want larger diameter prop or higher pitch or maybe both....
I have 17 fitted now.
Don S
At what rpm is this surging?
yrubugn
Not 100% as the tach is erratic I guess in the 3500-3800 range.
Thinking its tune related engine still fitted w oem mercruiser parts it looks like, seemed to improve after running a bit both times out this year...
achris
More fish than mountain goat
Higher pitch... and you are going to need to go to about 23 or 25...
With that 17" prop I suspect the engine is so over-revved that it's just running out of breath, hence what you feel as surging...
Chris....
achris
That could indicate an ignition problem... Is the tacho erratic in other rev ranges?
yrubugn
Seems to generally flutter or be off in higher ranges
Just reched my prop its a 19
achris
What spark plugs are in?
Don S
You have engine problems, not prop problems right now. You have an outdrive gear ration for a V6 and with a 17 or a 19 prop you should be hitting close to 6 grand with your 5.0LX
You need to get an inductive tach on a timing light or something and find out what rpm you are actually getting. But before you test, disconnect your helm tach and take it out of the equation.
