Pont00nlife
Thread starter- Joined
- May 20, 2018
- 9
I've read a bunch of forums on here about this, but I still can't seem to figure out the issue. I just bought a pontoon boat with a 1989 Johnson 70hp VRO. (VRO was disabled) the motor will not start without the electric primer and will not idle. Runs fine it seems at higher RPMs. And only if I have it in a tank. It will idle if only on muffs.
Here's what I've done so far; spark plugs were replaced and checked for good spark. Fuel filter was replaced. Primer bulb and hose was replaced. Carbs were cleaned and I rebuilt one since the float was out of adjustment and the needle seemed worn. I tried hooking the fuel supply to a separate brand new tank of gas and no change. I poured sea foam deep creep in the carbs and cylinders and let sit for about 8 hours, still the same issue. Lastly.. And my big fear is in this one. I did a compression test, I am sitting right about 90psi on all 3 cylinders. I have read this as low compression but I have also read that consistency is more important than actual numbers?
One last thing, I bought this boat from Oklahoma and brought it home to Colorado (a 4000ft+ elevation change). Would I need new jets in the carb? Could that be my issue? Could my fuel pump not be supplying enough fuel at idle? Or am I just screwed with low compression?
Thanks for your help!
