89' Johnson 70hp won't idle, help!
Pont00nlife
I've read a bunch of forums on here about this, but I still can't seem to figure out the issue. I just bought a pontoon boat with a 1989 Johnson 70hp VRO. (VRO was disabled) the motor will not start without the electric primer and will not idle. Runs fine it seems at higher RPMs. And only if I have it in a tank. It will idle if only on muffs.
Here's what I've done so far; spark plugs were replaced and checked for good spark. Fuel filter was replaced. Primer bulb and hose was replaced. Carbs were cleaned and I rebuilt one since the float was out of adjustment and the needle seemed worn. I tried hooking the fuel supply to a separate brand new tank of gas and no change. I poured sea foam deep creep in the carbs and cylinders and let sit for about 8 hours, still the same issue. Lastly.. And my big fear is in this one. I did a compression test, I am sitting right about 90psi on all 3 cylinders. I have read this as low compression but I have also read that consistency is more important than actual numbers?
One last thing, I bought this boat from Oklahoma and brought it home to Colorado (a 4000ft+ elevation change). Would I need new jets in the carb? Could that be my issue? Could my fuel pump not be supplying enough fuel at idle? Or am I just screwed with low compression?
Thanks for your help!
When starting one of these motors you need to push the key in when cranking it over.----The primer valve opens up to allow fuel into the motor.----The primer valve replaces old time choke flappers.
flyingscott
Get a different gauge and retest compression. Does spark jump a 7/16" air gap? If those are good look at the idle orifice # and high speed jet and compare it to the factory schematic. There are 2 different sets of carbs that yr.
oldboat1
Need to measure the spark with a proper open air adjustable tester (cheap -- auto parts stores). Test with plugs removed. Look for 7/16 inch as suggested, and crisp. Believe the initial slow speed idle speed setting on the 70 (later carbs) is a couple of turns(?). Adjust from there. Need some back pressure -- tank is better than muffs. Lake is best.
Seafoam in the carbs won't clean them, if dirty carbs/jets turn out to be the problem. You would have to fully disassemble and soak each of them (my preferred soak is lacquer thinner) -- then some poking with soft wire or some mono, followed by carb spray in all openings. Top compression fitting -- domed expansion plug on top -- needs to come out to access the idle circuit.
flyingscott
2 different sets of carbs for that motor late and early. And the late ones were very late and the scew will not fix high altitude jetting.
Pont00nlife
I do not see any adjustment screws. Everything is fixed. I will pull the jets out and compare the numbers to the factory numbers for my model. Is the main jet the one I need to look at? Also, I will test the spark plugs for the 7/16 gap. Thanks! I'll let you know what I find!
Btw. I did tear the carburetors down and clean them and all passages are clear. I did not take any of the compression fittings out though, should I do that? Honestly the carbs looked WAY cleaner than I expected for a 2 stroke. Felt like I was cleaning a new carb off the shelf.
Pont00nlife
So I'm having a hard time finding info. But, it looks like if I have an early carb with part # 0431982 it's supposed to have a 33 and 65d jet. Mine are 0431983 with a 33 and a 63d jet. Is that a superseded part number?
flyingscott
Not a supersede part #. Before anything get a different gauge and retest compression. There should be an altitude chart for jetting your motor any dealer will have it. 65d looks to be the correcr jet for low altitude.
Lightwin 3
What struck me was; "will only idle on muffs".
That makes me wonder if it is hitting on all three?
When it is running, are all three cylinders roughly the same temperature. Hold your fingers on the head and then the block for all three.
A triple or v-4 will surprise you running on muffs-no back pressure. As soon as you dunk them-no go.
Pont00nlife
I hooked the gauge up to my air compressor and it's reading accurately compared to the gauge on my compressor. Don't know if that is a good way to check accuracy but it seemed like it would be. Compared to the altitude chart I found, the jet that's in the carbs now is for high altitude. (63d) Weird since they were running damn near at sea level.
Pont00nlife
Update! So I bought a spark gap tester today and ran i quick test. Cylinder 1 the spark was very intermittent, the other 2 cylinders seemed great. Not too familiar with these engines as this is my first outboard. I hear to check the power packs? Switch the wires with one of the other packs and see if the problem follows? Or is there something else I should be checking?
Pont00nlife
Update! I replaced the ignition coil for the cylinder with intermittent spark and immediately noticed a difference. Sounded like a new motor! But, still wouldn't idle. Adjusted the idle screw and it idled beautifully. So we took it to the lake to test it out. Guess what, I could barely get it started! And it definitely wouldn't idle! I can't win, can someone help?!
flyingscott
You cannot set the idle on muffs. Did you use the high idle lever when starting? Did you us toe the cold start procedure? Idle needs to be set on a warm motor in gear. Your idle speed on muffs should be around 11-1200 rpm.
Pont00nlife
I tried throttling up while cranking and using the electric primer. Hooked up to the muffs everything is fine but I put it in the trash can and the exhaust back pressure, or the fact that it has to pull water in itself is enough to not let it start. It just cranks and cranks. I tried spraying starting fluid in the carbs just to see if I had a fuel delivery problem, but that didn't change anything. I don't know what else it could be. I don't think it's the stator, I charge it up with my battery charger and it cranks crazy fast and still won't run.
