scottmm73
Thread starter- Joined
- Jun 9, 2012
- 261
Re: 89 Force 85 HP #3 cylinder compression and ignition woes
Well I found someone to do the re-bore, he says the first oversize will clean it up nice. Have ordered the pistons and everything needed just waiting on the stuff to come in for rebuild.
While I'm waiting I'm going to do some preventive maintenance on the lower unit. I have ordered all new gaskets and seals for lower unit. I have a question related to the 89 lower unit. According to the clymer manual the 89 didn't have a 2 piece drive shaft, however there is a note in the manual stating that they only have diagrams of the most common assemblies. This is a G version in the 89 year (856A89G), so I'm assuming this may be one of the first units to entail the 2 piece drive shaft.
Anyways to get to the question, I want to remove the drive shaft seal, figure 75 page 450, shows a one piece drive shaft seal for the 89 one piece driveshaft, however, figure 76 page 452 shows a 2 piece drive shaft seal. I'm hoping the seal/gasket kit has the right one.
Lower seal?
Upper seal?
Or all one piece?
The manual doesn't state how to remove it. Should I just take a screw driver and pry it off like a tranny output shaft seal? I wont damage the cover will I?
Now for a corrosion problem. Can I just take some emory cloth and clean it up the mating surface a bit?
Lower seal?
Upper seal?
Or all one piece?
