'89 Evinrude 48 SPL tilt assist question
Chrissea
New here- I just bought a sweet 1960 Dorsett Catalina that came with the above mentioned engine. From what I understand (and see) it has a hydraulic manual lift assist system. The motor is almost impossible to lift from inside the boat, which makes me think this thing isn't working. Today I lifted it up a few times from the ground so I could spray anti-seize on the lock mechanism (the one that locks it for travel) and I realized if I tried to lift it quickly it was actually harder to lift than if I did it slow. This seems to indicate to me that the hydraulics are not working, and acting like a damper making it harder to lift, rather than easier. Is there any adjustment or something I can look at in the lift mechanism that might make it work again or is it likely to be the 'jack' portion of it that's gone bad? If so that would be a drag, as that part costs something like $600, at which point I feel like it's getting close to the price of an aftermarket power tilt/trim unit, and if I was going to spend that much I'd probably look at repowering instead, as I've heard this boat handles up to 80hp nicely. Any guidance would be appreciated! I've heard this is a nice motor but not being able to lift it from inside the boat sucks.
Chinewalker
Those assist units are notoriously problematic. Much better off if you ditch it entirely and go with a power trim unit. You can get used OEM ones for about what you'd pay for the part you need.
Joe Reeves
The "assisting cylinder" is Nitrogen pressure filled. Unless some moving area of the tilt assembly is corroded, rusted, jamming due to some reason.... the cylinder has failed and will require replacing if you're determined to restore that portion of the engine to its original condition.
boobie
That tilt is not worth repairing. Try CMC.com for an after market one or trade the whole motor in. JMO.
Honorary Supreme Mariner
Have you read the manual on that particular system ??
Stumpalump
The lever on the starboard side operates a cable. Inspect and adjust the cable. When the cable stretches you can not lift the motor. Adjust it so the housing is longer.
Chrissea
Thanks! I thought I remembered seeing something about the cable adjustment elsewhere. I'll check that out.
