New here- I just bought a sweet 1960 Dorsett Catalina that came with the above mentioned engine. From what I understand (and see) it has a hydraulic manual lift assist system. The motor is almost impossible to lift from inside the boat, which makes me think this thing isn't working. Today I lifted it up a few times from the ground so I could spray anti-seize on the lock mechanism (the one that locks it for travel) and I realized if I tried to lift it quickly it was actually harder to lift than if I did it slow. This seems to indicate to me that the hydraulics are not working, and acting like a damper making it harder to lift, rather than easier. Is there any adjustment or something I can look at in the lift mechanism that might make it work again or is it likely to be the 'jack' portion of it that's gone bad? If so that would be a drag, as that part costs something like $600, at which point I feel like it's getting close to the price of an aftermarket power tilt/trim unit, and if I was going to spend that much I'd probably look at repowering instead, as I've heard this boat handles up to 80hp nicely. Any guidance would be appreciated! I've heard this is a nice motor but not being able to lift it from inside the boat sucks.
